BringToFront does not working for section lines
I am very new to VisualARQ. For now, I am wondering how to show section lines in a plan view. I have seen that it is possible to use the BringToFront command to see the lines on each level, but that is not working for me, because it only shows the lines when all levels are activated (when you turn off a level, the lines disappear).
Thanks for any help!
Hi @vin.iab. the option with the ā€œBringToFrontā€ command will help you if the section lines are located at the lowest level elevation.
But a better option is to select the section line and uncheck the property ā€œClippableā€, under the section attributes:
This works, Francesc! Thank you very much. In this case, I need to move the section line to the highest level, so that the lines overlap other elements, and uncheck the clippable option. Just out of curiosity, I would like to know if the ā€˜BringToFront’ command is not working correctly or something (in the screenshot, my section lines were at the lowest level (ground floor) and the clippable option was disabled).
Hi @vin.iab the BringToFront command should work with geometry as long as it is not clipped by any clipping plane or VA section/level.
