Setting height to 7000 on objects of varying heights does not set them all to 7000. Instead it makes some relative height and updates the scale factor.
I was under the impression that if I removed lambda in the size box then it would become absolute sizes?
Oooooh yes been reported since V7. Still a bug. Been marked for a future fix.
I got tired of waiting and wrote a python script resize it in Y axis and aligned the bottom edges for what I was needing it to do. Here it is if it is helpful. ResizeYAligned.py (1.5 KB)
It did work correctly in the early version of 7… but was broken mid release cycle and never fixed. Maybe one day… they will fix it.
Your not the only one that has notice this bug. Make the transform individually almost useless. I think that was the point of the check box. A user should be able to input a number with that object selected and they should transform all to that measurement, not add to the current size by that amount.
I love when someone points this bug out. Gives me a chance to ring the bell again…LOL
