I’m trying to use box morph to distort some geometry using a workflow that can be seen in a Walter Zesk video on LinkedIn Learning.
I create two surfaces with just one of the points displaced vertically between them (red arrow), and create a blended box between the surfaces. This should, ideally just pull the part of the geometry nearest the displaced point upwards (yellow arrow), but instead the geometry is being pulled in another direction (blue arrow).
The box vertices are definitely in the same order etc. so not sure exactly what’s going wrong.
Box Morph Issue.gh (33.5 KB)
