Black screens in viewports/ graphics card issue?
I’ve been having an issue where, as i was drawing curves, they were not appearing. They would only appear highlighter in yellow when I would select. Now my rhino will not open properly and is not functional. When i open a new file or a previous file, the program opens but the viewports are all blavk and I can’t draw anything. I am out of ideas and i am trying to figure out if i need to buy a new computer… does anyone know if my graphics card or some other component of my desktop is not compatible with rhino 7? Are there solution? Thanks.
System Info
Rhino 7 SR2 2021-1-12 (Rhino 7, 7.2.21012.11002, Git hash:master @ 2f08cf516ffc716c4c4a369abf7625798ef79bca)
License type: Educational Lab License, build 2021-01-12
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.15.7 (Build 19H512) (Physical RAM: 16Gb)
Mac Model Identifier: iMac13,2
Language: en-CA (MacOS default)
NVIDIA GeForce GTX 675MX OpenGL Engine (OpenGL ver:4.1 NVIDIA-14.0.32 355.11.11.10.10.143)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1 GB
Graphics: NVIDIA GeForce GTX 675MX
Displays: iMac (109dpi 1x)
Graphics processors
NVIDIA GeForce GTX 675MX (1 GB)
iMac (2560 x 1440)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
Apple: Apple Wireless Keyboard
Apple: Apple Wireless Trackpad
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.2.21012.1002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.2.21012.1002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.2.21012.1002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.2.21012.1002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.2.21012.1002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.2.21012.11002
/Applications/Adobe Bridge CS6/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.2.21012.11002
Please post the results of the Rhino command _SystemInfo. This will give the information in a safe manner.
Thanks! I am obviously clueless
In Rhino type the command _SystemInfo. Then copy the text from the dialog that appears into a reply here.
Have you restarted your Mac recently? Are you connected to any additional monitors? If so, I don’t think your graphics card can handle those as well. If you have a Time Machine back up of your Mac you could also try updating to Big Sur which will update your graphics driver.
“Cmd + Shift + 4” will also allow you take a screenshot and saves it to the desktop.
