When I open rhino all 4 viewports are black. If I open an existing project I can see the layers on the right but I still can’t see any of the work in the viewports. I ran the compatibility troubleshooter on my computer it says that “Rhino is incompatible.” Seems like a computer issue… but I’m stumped on what to do.
Hi Isabelle,
Please type systemInfo in the Rhino command line and paste the results here.
You most likely have a 1gb video card or a Radeon card. AMD Radeons have had issues with drivers but will work if you reduce the load by unchecking the GPU tessellation in the File>Properties>View>OpenGL dialog.
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Educational, build 2023-02-27
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 7.9Gb)
Computer platform: LAPTOP - Unplugged [91% battery remaining] ~125 minutes left
Primary display and OpenGL: Intel(R) Iris™ Graphics 5100 (Intel) Memory: 1GB, Driver date: 10-16-2017 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4835
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.3
Shading Language: 4.30 - Build 20.19.15.4835
Driver Date: 10-16-2017
Driver Version: 20.19.15.4835
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.4.7920.28915
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
1GB is well below the system requirements. You may be able to limp along if keep as much geometry turned off as possible, work in one viewport & always in Wireframe.
A driver update alone might solve the Black Screens, if not turn down your openGL settings (same dialog as the GPU tessellation)
https://www.intel.com/content/www/us/en/download-center/home.html
