started a drawing, worked for 2 hours,saved and closed.
Now everytime I try to open it again, I see BLACK, happens with every drawing.
I have the last version of MAC and Rhino, read all FAQs but still, I just cant use the app
Run systemInfo and post the results here…
also use the command 4view twice in a row and see if that helps
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro17,1
Chip: Apple M1
Total Number of Cores: 8 (4 performance and 4 efficiency)
Rhino 7 SR19 2022-6-29 (Rhino 7, 7.19.22180.09002, Git hash:master @ 87eeb0270c74a3e5ecc603402afbf263ed32b37d)
License type: Evaluation, build 2022-06-29
License details: Cloud Zoo
Expires on: 4548017-03-01
Apple macOS Version 12.4 (Build 21F79) (Physical RAM: 8Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro17,1
Language: en (MacOS default)
Apple M1 (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 5461 MB
Graphics: Apple M1
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1
Color LCD (1440 x 900 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.19.22180.1002
I ran it, but nothing happened. first time, the screen moved a little bit, but thats all
Please upload your file and reference your threads in the report.
Thanks
A link to the threads would suffice.
I cant even draw a rectangle or a single line snap point it to any determined place (endpoint, intersection, tangent, perpendicular…nothing) I tried everything, have the latest version of Rhino , and of MAC . searched in Settings-Advanced all the options the FAQs suggested, but nothing, the program is resulting completely useless so far ( and I already opened another topic because on top of it, when I reopened my drawing next day I started, I just saw everything BLACK)
What is your system info? (type systemInfo in the command line)
Black screen is typically an indication of hardware not meeting minimum system requirements.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Z-Buffer depth: n/a
Graphics: Apple M1
Graphics processors
Apple M1
USB devices
None
Bluetooth devices
None
None
Third party plugins
This is the info for my mac, and I sent you the system info of the rhino version I have, can you help me see if its ok on both ends?
Hardware Overview:
Chip: Apple M1
Memory: 8 GB
System Firmware Version: 7459.121.3
OS Loader Version: 7459.121.3
Serial Number (system): C02GX27TQ05H
Hardware UUID: 9590CAB0-E995-5CE5-85B2-1E9970C943A9
Provisioning UDID: 00008103-000549393E80801E
Activation Lock Status: Enabled
I think Im ok regarding the Hardware , space, memory … from what I understand, I should be ok
Hello- it looks that way to me - @Japhy - do you see anything amiss here? I’d get more RAM, but 8 Gb should work…
I opened new models, new drawing and they all look the same.
In case the black goes away, and I can draw, the snap problem, I really tried everything (I think) and my snap setting is this:
I also had SmartTrack clicked, but I un selected it
Im sorry, Japhy, I don’t understand , you mean, copy and paste the entire conversation?
