Biomorpher not in GH
I can’t see Biomorpher plugin in Grasshopper ? I Have Rhino 7 and everything is unblocked. @johnharding
Did you install this through _PackageManager?
No, by dropping file in Component folder …
Can you see if installing through _PackageManager resolves your issue?
Hey, no it did not work with packageManager … Some people have the same issue on the Food4Rhino page … Biomorpher | Food4Rhino
One of the team from Biomorpher posted this; I need some more information before I can help. Can you tell me which version of Windows (if at all) and Rhino you are using? Can you also let me know if you have Octopus installed (or anything else that is dependent on the Helix Toolkit) and what version this is (you can right click on the dll file, and view this in the attributes tab).
I have no Octopus … and it was not posted for me, but long ago for someone else
Please run _SystemInfo and post the results here
Rhino 7 SR23 2022-10-9 (Rhino 7, 7.23.22282.13001, Git hash:master @ a931168ca9426920ae6aa97218710b662f17fc39)
License type: Evaluation, build 2022-10-09
License details: Stand-Alone
Expires on: 2023-01-23
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9664
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9664
Driver Date: 6-1-2021
Driver Version: 27.20.100.9664
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.23.22282.13001
I see nothing peculiar in your system info that I expect could cause this issue.
Just to be sure: after installing this plugin, there will be no separate toolbar for this plugin. The biomorpher icons will appear in the main toolbar, Params tab
I found it, thanks.
