I was trying to install a few plugins (weaverbird and ngon) in grasshopper but suddenly GH broke down. I couldn’t install WB neither ngon by packagemanager.
SS:
I’ve just unistalled RH and everything the same. Plz help
SS:
Hi Amaro -
When you check the plug-in manager, what happens when you enable Grasshopper and then restart Rhino?
Hi -
Did you use the PackageManager to attempt to install those two plug-ins? If so, please see if you can uninstall them from the PackageManager.
If you installed them manually, I’d look for files related to these plug-ins and delete them.
Finally, I’d try to run a Repair
on the Rhino installation from the Windows Control Panel.
I’ve just tried to run the PackageManager command but it didn’t work. (It doesn’t work anymore)
I couldn’t install Ngon/Wb so there’s no any file. Food4Rhino automatically opens RH and PackageManager but it doesn’t work with both plug-ins.
Recently I tried to ‘repair’ RH but nothing happened.
Hi -
Please run the Rhino SystemInfo
command and copy-paste the result here.
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Educacional, build 2022-05-04
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [85% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 2GB, Driver date: 4-20-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.59
> Integrated accelerated graphics device with 1 adapter port(s)
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-29-2022 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-20-2022
Driver Version: 30.0.15.1259
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 7-v2\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7-v2\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7-v2\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7-v2\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7-v2\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7-v2\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7-v2\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7-v2\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
C:\Program Files\Rhino 7-v2\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7-v2\Plug-ins\Displacement.rhp “Displacement”
This is from command window
Hi -
I take it that the PackageManager
command still works?
Could you post a screenshot of the “Installed” tab in that dialog?
Nope, PackageManager doesn’t work. When i run the command nothing happen.
About “installled tab” i’m not sure what you mean
Hi -
What does the command line say when you run that command?
It sounds like something got seriously messed up on you computer and it’s weird that a Repair doesn’t fix that. A long shot, but I’d try changing the update frequency to the release candidates and get Rhino to download and install the latest candidate.
