Hello @johnharding
As we were talking at Biomorpher Forum, here it goes my query.
I’ve installed Biomorpher 7 on Rhino 6. But it shuts down my Grashopper and Rhino when I try to run it. Biomorpher 6 works great, but I need to work with surfaces, not only meshes.
You said that you need more information, what could it be?
Thanks again for your attention.
Thanks for finding me on here. Sounds like a strange one. Have you got any other plug-ins installed that depend on the same libraries (MahappsMetro or HelixToolkit). Examples could be HumanUI, Ocotopus, Wallacei, etc.
John.
Sorry, I don’t see HumanUI, Ocotopus or Wallacei on that tab control! There is Human, but that’s something different.
It might be something I don’t know. Ok, so when you copied the dll files into the libraries folder, did it copy over any old ones with the same name?
By the way, surfaces are best used meshed in Grasshopper before putting them into Biomorpher. This gives you more control over the way they are meshed. You can just use the mesh surface component before feeding anything into Biomorpher 6 if that works. Not ideal in terms of not being able to upgrade though granted.
Hi @arqcampoy77
Could you try this pre-release instead that I just made:
The version of Mahapps (and windows interactivity dll) is now identical to that used with HumanUI, and the HelixToolkit is renamed to attempt to avoid version clashes.
Please let me know how you get on, and I’ll turn this into an actual release. Thanks!
John.
Hello John
I did copy the dll files as you mentioned. Perhaps it might be some other configuration of my PC.
But I’m experiencing some progress working with meshes anyway.
Thanks a lot for sharing. I’ll try it during the next week.
For now, I’m working on a paper about GH/Biomorpher/Galapagos as a part of my PHD’s on digital architecture. So I’m overloaded in the next few days.
Your help has been extremely important to me!
No problem, glad to help. Hope the PhD goes well. Cecilie Brandt-Olsen and I published something in IJAC on Biomorpher in 2018 if you need a ref.
Take care, John.
Hi john
I just discovered your work at IJAC. Very interesting analysis. It will certainly help me with the theoretical foundation of the tool.
Thank you very much for your support, kindness and generosity.
Best regards!
Hi john
I tried to install your new version 0.7.1. It didn’t work for me. The icon does not appear on the ribbon. I unlocked all filles.
Do you know if it’s working for other people?
Actually I think I was tricked also, as I thought renaming the assemblies was working, but it turns out Grasshopper was instead also loading the helixtoolkit libraries within HumanUI! Please try this one instead, copying the Biomorpher folder across:
Thanks for your help with this. I think assembly conflicts is a known headache with little in the way of workarounds. At least the Mahapps is now updated. Other than this, I’m not sure what else to explore.
Hi John
Same error. The icon does not appear on the ribbon.
It seems that Biomorpher is not installed.
Sorry about that. I haven’t heard of this issue with anyone else (despite quite a lot of recent downloads) and there’s not much else to suggest really. Perhaps you could move all other libraries somewhere else, then move them back one by one and see where the conflict might occur? As I don’t have your component library in front of me that’s something I can’t do here.
It’s not even appearing is interesting though. There might be some detail on the Rhino Command line when you’re launching gh about why it cannot load, have a look for messages.
Sorry about this.
No problem, John. You’ve already helped me a lot.
I was able to run the experiments I needed with the version 6 of Biomorpher. Turns out, meshes were the best type of objects to my research.
Thank you very much, for all your attention and kindness
I also have the issue with Rhino shutting down when I try to run the Biomorpher component. I open it, run it, and then it shuts down after having finished the iterations. I can’t access this GitHub url you sent. I unblocked all files. I did however have to replace HelixToolKit.dll on first download, maybe this was a mistake, don’t know how to go back now tho…
Hi Herman, are you using Rhino 8?
Not sure about this one, maybe I can try and recreate the issue or update to the latest Rhinocommon.
For reasons unknown, github has listed my account as ‘spammy’, I have no idea why. That appears to be why there is a 404 error nowadays. In fact thanks for raising this, as I have now contacted github support about this!
The 0.7.0 should work though from the food4rhino page, one down from the dead link.
There was always this problem with the clash with human using a different version of the helix toolkit. If it is indeed that, there isn’t a simple solution unfortunately I can think of, other than replacing the file each time with the different version. A bit rubbish, but I guess that is the limitation of having the libraries installed in this way.
Herman, also maybe try this. I’ve managed to get my git back online. Mahapps is aligned with HumanUI in this version, so in theory they should both now work:
Thanks, John. The program works when I have only one genome attached, but when i try to connect several genomes, Rhino shuts down. I tried with the 0.7.1 release. Maybe the program can’t handle too many variables? I am using it together with Karmba3D btw.
That’s strange, no there shouldn’t be a limit on variables. You could try using a gene pool instead maybe.
Otherwise feel free to attach something for me to look at to see if I can recreate the issue. I am a karamba user also. John.
Hi John, I am having some trouble as well, but only with Rhino 8. I have the latest version of biomorpher installed, 0.7.1.
It seems to work fine in rhino 7 (the files should be identical as the libraries seem to be located in the same place for both rhino 7 and 8). Any ideas as to what could be the issue or any plans to update compatibility for rhino 8?
Thanks!
