Looking at the Rendered mode with Custom material, in V8 and before we could see edges and full range of transparency of objects with Custom material. In V9, even with transparency set very high, the objects are almost opaque and no edges show thru. I can get the “old” (desired) look by disabling the “Use Advanced GPU lighting” in the Display Mode setting, but I assume some display features like bump etc. will be lost as well. In V8 and before, the “Advanced GPU lighting” was on with the “correct” transparency display. Is this by design? Why did this behavior/look change?
The reason this was changed was because the refraction effect would also refract the wires/edges, and it did not look good. I will try to see if we can get the wires in the back visible again, but not affected by refraction.
Thanks - this is actually made with Custom material (not Glass per your YT) but I guess its the same issue. I remember in the past seeing distorted wires which I agree looked odd.
The problem I see now is mainly lack of the wires seen with transparency but also even cranking up the transparency to 90+ percent leaves the objects almost opaque because of the refraction effect. It’s probably nice to have the refraction for some workflow, but here we don’t really need this, mostly display of architectural glass for real-time Rendered-looking modeling workflow, so I wanted to ask:
Is there a way to turn-off the refractions (globally or per display mode) but keep all the other features of Advanced GPU?
If I keep advanced GPU off to keep the “old” look, what other display featured will be lost?
