V5.
What would be the best way of turning my aircraft object into a side view line drawing, where only the edges of surfaces, and my rivet lines (circles) are seen, so as to become a typical aircraft side view plan in a book ?
I try for make2D, and after two minutes of a timer, I exit to see emails, return and all is not clickable, no timer, end task and its running, select and end task, says not responding.
It wont make2D.
I try again selecting current view and after a while I get 2D, though I need to remove some details as the cowling was not a single surface due to its complexity, so I see lines of all the surfaces that made it.
What should I do, one view at a time ?
Steve
