Bending a group of crv along a crv in a circle
Hey there,
I am trying to find a solution for a formation process which I hope is possible with grasshopper. I want to bend, circulate a group of crv along a crv into a circle. I tried to use the bend tool but it does not serve the purpose. I made a little sketch for what I want. I am very grateful for any help.
In Rhino I would use the Flow command. I don’t know what the Grasshopper equivalent is.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/flow.htm
Try dividing your circle. Make a 2 point ray taking the center of your circle to each point division. That should give you an orientation direction. then orient your objects on your crv.
That might work
see my idea of a commad-function-component - mapping tabel..
