Hello
How can I bend a group of curves around a circle? I’m looking for the equivalent of the Rhino “flow” command, I’m sure it’s easy but I can’t find it, sorry
In the image, on the left this is what I would like to obtain, I did it with flow on rhino
Thank you in advance
double-click on the canvas to get a search field.
type:
flow, enter.
the component is called → flow
click on the resul
if this does not fit - check other components in
Transform → Morph
thank you for your answer but I don’t have a “flow” component when I search.
And in the morph tab, I didn’t find anything that would work, there is “surface morph” but it’s for surfaces and I would like the equivalent for curves, I haven’t found anything like it
this is weird… is the following working on your rhino? (I guess you’ll need R6 or later…)
Flow_in_Py.gh (15.6 KB)
no it doesn’t work. In fact I’m on rhino 5, I have to install 7 for it to work
Thank you
