Hey Guys,
I am facing a problem with bending these curves in a complete circle, please help me with the trick to doing that.
Attaching rhino reference file also…
Best regards
Huzefa malik
Bending pattern into circle.3dm (547.5 KB)
Hey Guys,
Best regards
Huzefa malik
You can use the Bend command.
I used the bend command, But it just does an arc, not a complete circle.
use flow and take the middle curve you have on that circle as a target.
Thank you very much, It works
From Rhino Help:
If you still have questions upload a .3dm file with your curves. Drag the file to where you type a post, or click on the vertical arrow icon above where you type a post.
