So i made a row of squares and want them to curve.
But the objects are not perpendicular on the curve.
Then I added control points to the center-bottom of all objects but that makes no difference.
Why are the objects not perpendicular on the curve? - and how to get them that way?
Hello - are they perpendicular once the command ends? The preview is a cheap trick. Hm - here they are perp, on Windows, Iâll go over and try the mac. OK, now I see on Windows as well - you need enough of them to see it. Iâll investigate.
https://mcneel.myjetbrains.com/youtrack/issue/RH-48937
Thanks for the report.
Hi Pascal.
After âdoneâ they are like the screenshot.
@Robbert_Vader - Iâm told this cannot be made to work as you (and I) expect - you can use Flow to an arc with Rigid=Yes to get the result youâre after.
I see. Thanks for checking it out. Ill try your suggestion. Thanks!
Why donât you try polar array.
Hi Mike. Thanks, wow, that looks super; just as i had in mind!
Im new to Rhino so donât know all the right commands to get things done.
So i try and experiment with those I understand but im aware theyâre not always the right one for the job.
I did array before though but remember the start and end didnât equally distanced from the vertical line in my trial - why i tried to use the bend command instead but that also didnât work out well.
But from the replies i will learn how to get it done well.
Thanks!
Robbert, no problem we are all learning. This is a harder task then it first appears, here is an explanation of what I did.WHen I tried a polar array it rotated the rectangle but in entering 180 degrees to array around the half circle it placed the first and last object at the zero degree and 180 degree location. Your example has the first and last rectangle within the 180 degree sweep. After posting my last picture which used the, " Flow along Surface", command found under transform, I tried the, âFlow along Curveâ, command. that solution is the one on the left side of this image.
This was much simpler then the, âFlow along Surfaceâ technique. Here is what I did, I used analyze command to find the length of the half circle, then created a line of the same length. Then array the 41 rectangles along the length with the first and last rectangle fitting exactly within the line length. Then select the flow along curve command, select the 41 rectangles, hit return. select the straight line near end, hit return. Select the half circle near the same side end, hit return.
Good luck
Youre a great help; ill rebuild my structure the way you did and hopefully the same results ; )
Thanks Mike : )
