Orient perpendicular to curve - Rhino 5
Hi everyone,
I’m having problems using the tool “orient perpendicular to curve”. When I try to place the objects in the curve, they are positioned horizontally and not vertically, as the image I attached here (on the left: How it is / On the right: How it should be).
I am following a tutorial correctly and it works perfectly on Rhino 4, but when you follow exactly the same steps on Rhino 5, this problem happens. (A friend of mine who has Rhino 4 and Rhino 5 helped me following the same tutorial on the two Rhinos and confirmed this to me).
Does anyone have any idea what might be going on?
Thanks in advance,
Hi Tatiane- do this in the Front or Right view - which ever has the view through the ring and the CPlane parallel to the object to be oriented. The rectangle can be hard to orient to begin with in a way that the command likes - with the Perp option, I’d set it up as in this clip-
http://screencast.com/t/ng2s7SWRKJW
See also Flow, with the Rigid option - you’d make a linear array and map that from a line to the curvey curve .
Hi Pascal,
Thanks a lot for your help.
I’ve tried to do this in all viewports, and the result is the same. I just tried to use Flow, as you recommended, but it didn’t work, maybe because I’m not familiar with this tool.
I got a similar result with Polar Array, but I think it will not be convenient in all ocasions I need to have this result.
Honestly, I’d like so much to be able to use “orient perpendicular to curve”, because I’ll need to use this often. I don’t understand why in Rhino 5 it’s not possible to do that.
Tatiane.
Hi Tatiane- notice the orientation of the object and the curve relative to the CPlane in the clip…
Hi Pascal,
I’m having the exact same problem and the video is no longer available.
I tried to perform “orient perpendicular to curve” on front or right view and I don’t get the desired result (same as in Tatiane’s pictures).
Can you please upload the video again or explain in more details how to solve this issue?
Thanks a lot,
Guy
Hi everybody,
I encountered this also a numerous times. I tried all different viewports, orientations of the input object, etc. got really frustrated… till I found out that sometimes you don’t need the “perpendicular” option.
Next time you facing this problem try simply _OrientOncrv. It might do what you need.
gr, Tobias
Thanks Tobias,
I tried your solution and a funny thing happened, the orientation was OK but upside down i.e. the gemstone was on top of the ring and upside down. And if I clicked on “Perpendicular” the whole part changed its orientation again and won’t change back.
Any help would be appreciated.
Thanks,
Guy
Hi Guy - I don’t know what happened to the clip - it does seem to be gone - can you send your example file, I’ll see what I can do…
Chapter 6 - VolumeRing.3dm (310.3 KB)
Hi Guy - in this case, (I know it’s really kind of hard to sort out) the CPlane is not a useful one as the file opens so set that to Front. Then the Perpendicluar options plus 'Rotate does the job.
Hi Pascal,
Thank you so much for solving this issue and for taking the time to make this video.
Thank you,
Guy
