Hi guys,
I created a pawn like shape and now i want to weave lines around the different sections (circles).
I attached some images of the shape. My idea was to create 2 concentric circles for every section, one with a slightly bigger radius, the other slightly smaller.
If i divide the curves and then try a weave it will only connect lines between the concentric circles and not across the whole pawn shape.
Any suggestions?
I did this a while ago…
You didn’t attach your file so I can’t check if it will work. Download the definition and plug your surface into where shown in the def. It might work!
