I need to weave pipes around existing pipes
I managed to create the arches for my construction displayed on the picture and now need to weave pipes around the pipes I created and I have no idea how to even start tackling the problem maybe one of you has an idea which could help me.
The pipes which weave around the arches would have a radius of 25 centimeters and wrap around the arches kind of like in the photo.
I know that in the parts where the shape gets wider there would be big holes but there would be new pipes that don’t go from the start to the end that’s the next problem getting them done in 3D but maybe its possible to model them afterwards in rhino.
My grasshopper skills are pretty limited so I probably already took too many steps to get what I wanted.
3D Versuch Kopie.gh (90.0 KB)
basketWeaveOnGrid.gh (39.0 KB)
Hi, I reworked the original file you sent a bit, for how the rings and the profile tunnel are generated. It should be much easier to adjust the shape and rings if need be, and keep a smooth shape.
Thanks, this helps a lot. I will still have to make some adjustments but it’s a really good base to continue my model.
