Bake item number instead of data
Grasshopper newbie here. I want to sort a number of blocks based on their position. Point list is good to display it on grasshopper but I want to bake the list and not the value of the list (closed polyline or whatever). I’m sure it’s pretty simple buy I can’t recall any direct way of doing this.
The image below is displayed with point list, which is something I can’t use because when I bake it it makes text dots instead of normal texts.
Elefront is a great plugin for this type of workflow.
If you post a file i can make an example.
You could accomplish this with the Text Tag 3D component.
Perhaps not as flexible as some of the plug-in’s, but looks like it should work for your case.
Text_Tag_Item_Index.gh (9.3 KB)
-Kevin
