I have recognized that Rhino is generating Bad Objects after Unit Change in a model file … Some of these bad objects can be fixed by EXPLODE --> JOIN commands… But some of them cannot…
Does somebody have a solution about that??
Model File (without BadObjects) … Unit METER, Absolute Tolerance 0.0001
Hello - most likely, the model is out of tolerance after the units change - if you make something in meters, .001 and change to millimeters, then the existing geometry will have been made at a tolerance of 1 in the new units. But you do not say what the change is, so I’m guessing.
