Hi all
When I insert an object in Rhino in step format, the object is entered badly in both Rhino 6 and Rhino 7.
Audio that has no problem in Rhino 5
!!!This object was exported from NX
In general, Rhino works best if you choose a unit system whose absolute tolerance is around 0.01 to 0.001, the “size” of a small feature (like a tiny fillet or small curve offset distance) is >= 10 x tolerance, and the “size” of the model is <= 100000.
Does the bad import still occur when you change the units to meter in NX before creating the STEP file?
Yes, I know a lot of my work is done with NX, so I have not had a problem so far, it only enters Rhino in a bad way in this body, while there is no problem in Rhino 5
This is done in NX units= mm
I had a problem when I entered Rhino
