Unit was changed when I open them
I used to work in the Imperial unit. All of my files, including the files transferred by firms, are in imperial. But today when I opened them, they automatically changed into metric units. It’s too sudden, when i open the file, the unit on the bar still shows “feet”, but as long as the model is loaded, it will change to “meter”. Anyone has any idea about why this will happen? And it seems like I can never switch back to imperil. This stupid bug has polluted almost all of my files, as long as I open them their unit will change, and rhino never asks me if i want to change them or not. Rhino won’t ask me if I need to scale the model to fit either, so all the models are currently on the wrong scale with the wrong unit. Completely ruins all of my works. Also if I open a new file and change the unit to “Feet” and I paste a model from another file, it changes to imperial as well. So stupid.
Lol, i just opened a new file and save it in imperial, and when i open it again, it changes to metric. Epic phenomenon rhino. I want to clap for you.
I haven’t heard of this one before, are you using Rhino Inside Revit? that would at least pop up a warning and options for changing units.
Can you post system info please. This seems plugin related.
No, I don’t use rhino for Revit. But I do install VisualARQ today. I thought it might be its problem, but I have uninstalled it and restarted the computer. And the issue is still there.
Rhino 7 SR16 2022-2-15 (Rhino 7, 7.16.22046.13061, Git hash:master @ 98ed898fb42f6853548815cdbcd480c37746693b)
License type: 教育版, 版本2022-02-15
License details: Cloud Zoo
Windows 10.0.22557 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 1-27-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 515.36
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-27-2022
Driver Version: 30.0.15.1536
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 5.0\x64\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Program Files\Sunflower\Sunflower for Rhino\Sunflower 9.6 for Rhino 7.0\Sunflower.rhp “Sunflower” 9.6.0.0
C:\Users\Ostiu\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\3.0.3.0\XNurbsRhino.rhp “XNurbs”
C:\Users\Ostiu\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21047.851
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\ConnecterPlugIn (caac53be-e271-4b97-93e7-f3dd18d48ccc)\0.5.0.0\ConnecterPlugIn.rhp “ConnecterPlugIn” 0.5.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Ostiu\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\Ostiu\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.16.22046.13061
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.16.22046.13061
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.16.22046.13061
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.16.22046.13061
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.16.22046.13061
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.16.22046.13061
C:\Users\Ostiu\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Here’s my system infor. Thank you for the help again
Lets disable the plugins that don’t ship with Rhino and see if that resolves it, then add in one by one. Maybe start adding back in with substanceImporter, then V-Ray, X-nurbs,…
Not really working. I have disabled all the plugins I installed in the last 1 year. The problem still exists.
Here’s the new system info.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Rhino has definitely done something to my file when I open it, it’s just too fast that I cant see it. Because even if I just open the file (those were in the imperial unit), and do nothing but to close them once I opened them, it will ask me if I want to save the file or not (which have never happened before if i open a file and didn’t do any changes)
I tried to copy one of my files into rhino 6, and it told me “eInvalidDwgVersion” this never happened before either. This notification is from Asuni CAD. Any idea about this?
The model will still be successfully pasted though.
Asuni is VisualARQ
The above would happen if an a return is entered immediately after opening.
With plugins unloaded are you still getting spontaneous switching of units?
yep, all thing I described still exist
Please repair your Rhino install via Add Remove Programs, Rhino 7, Modify & Repair and reboot the computer (still maintaining no plugins) thanks.
Hi, I have reinstalled the rhino completely, the problem still occure.
Can you call our Tech Support line today during business hrs? 8-5 pacific standard time. They can team viewer in and get a handle on the atypical behavior you’re seeing. Thanks Rhino - Rhino Support
