Bad artifacts on screen
After running bongo and unhiding some group material this artifacts fixed on my screen. I cannot lost it or select it. If I save as only geometry they are gone.
I am using K4000 graphic card which is resisting to be updated.
Do you think my problem graphic card based or Bongo based.
Any help will be highly appriciated
These appear to be the Bongo pivot points of the objects. You can toggle the display of those in the Bongo settings.
thanks alot that solved my problem.
I was afraid it was a harware issue from K5000 graphic car.
Many thanks again
