Backface Setting: Single color for all objects
Is there a way to change the Backface Settings from RhinoCommon C# in windows? I don’t find the option to set Single Color for All Backfaces
I was trying to do:
 var displayMode = DisplayModeDescription.GetDisplayMode(DisplayModeDescription.ShadedId);
 if (displayMode == null)
     RhinoApp.WriteLine("No se encontró el modo de visualización 'Shaded'.");
     return;
 displayMode.DisplayAttributes.UseCustomObjectColorBackfaces = false;
 displayMode.DisplayAttributes.BackMaterialDiffuseColor = Color.Red;
 DisplayModeDescription.UpdateDisplayMode(displayMode);
Thanks,
Rafa
Hi @rafadelmolino,
I’ve logged the issue for a developer to investigate.
https://mcneel.myjetbrains.com/youtrack/issue/RH-86440
– Dale
I am working on this now jand, yes, you found oine thing I didn’t implement!
I am adding a BackIsCustom property which, when set in conjunction with UseBackmaterial, will turn that option on. I am going to doubke check this option in the process.
Thank you for pointing this out.
-Bill /)
Bill,
How I can track the status? I’m trying with SR18, but it is not there.
Thanks,
Rafa
Hi Rafa -
The issue is visible to the public so you can always check the state:
RH-86440 Backface Setting: Single color for all objects
This is currently still open and on the 8.x list of things to do.
RH-86440 is fixed in Rhino 8 Service Release 20
