Change color backface/material in shaded or rendered display mode c#
Hi all,
I’m trying to programmatically set the backface color of al objects. So far I’v found this setting with which I seem to be able to toggle the ability to set the color. But I cant find the property to also set the color.
On the rhinocommon page I can find this property:
public Guid BackFaceMaterialId {get|set}
However this doesn’t seem to be exposed at the moment.
Would this be the correct property to set color and material? Or is there another method?
kind regards Reinder
Hi @r.weenink,
Are you just looking to change the backface color of a display mode, or something else?
– Dale
Hi Dale,
Exactly the backface color setting in your picture.
Hi @r.weenink,
I see this is not possible in RhinoCommon yet. I’ve logged a request.
https://mcneel.myjetbrains.com/youtrack/issue/RH-81831
Thanks,
– Dale
RH-81831 is fixed in Rhino 8 Service Release 8 Release Candidate 1. Please test it out.
Hi Dan,
Thanks for the message.
Which version is this?
Kind Regards,
Reinder Weenink
@r.weenink - none of the above.
This has been implemented in Rhino 8.8. I don’t see a pre-release 8.8 NuGet package yet.
– Dale
