Turn on Color Backfaces visualization via RhinoCommon
Hi
I’ve searched the entire forum and can’t find an answer to this.
Thanks!!!
Nobody???
This might help:
-Kevin
Hi @cristiano.pasini,
do you want to enable it for a specific display mode or for a custom display (eg. conduit) ?
_
c.
clement
For a specific display mode (Rendered)
i’ve tried something which seems to toggle backface appearance in Rendered display on and off but cannot find how to set the color (or material) for the backface:
import Rhino
import scriptcontext
def DoSomething():
    sid = Rhino.Display.DisplayModeDescription.RenderedId
    dmd = Rhino.Display.DisplayModeDescription.GetDisplayMode(sid)
    if not dmd: return
    state = dmd.DisplayAttributes.UseCustomObjectMaterialBackfaces
    # toggle state
    dmd.DisplayAttributes.UseCustomObjectMaterialBackfaces = not state
    Rhino.Display.DisplayModeDescription.UpdateDisplayMode(dmd)
    # hack to make display mode really update
    rs.DeleteObject(rs.AddPoint(0,0,0))
    scriptcontext.doc.Views.Redraw()
DoSomething()
In my test, i had an open box which has green object color and a red material assigned:
BackFaceMaterialToggle
btw. there is also UseCustomObjectColorBackfaces but this only worked in Shaded display mode so i tried UseCustomObjectMaterialBackfaces which seems to change something in Rendered.
@stevebaer, since you’ve added this some time ago, is there a way to change the actual backface color/material itself ?
@dale, this is another example where the display does not update until an object is added to the doc. Same as this one.
_
c.
I’m speechless…thank you so much!!!
