How to change Backface color
Hi everyone!
I want to apply different color on surface or mesh.(Display - Object settings - Color Backfaces - Backface color)
There were few topics use Backdiffuse. I read that topics and tried to apply but it’s hard to me.
And I have no idea the Backdiffuse is correct solution…
So I got a few question.
  1. How to change Backface color using rhinoscript or Rhino common sdk?
  2. Can I use Backdiffuse in Rhino 5 windows? Now I using Rhino 5 in windows.
  3. Is there any site or doc which explain how to use Rhino common by python?
Thank you.
Jinwook Kim.
Hi @jinwook_Kim,
Are you trying to dynamically draw objects with a different back face material color? Or are you trying to change the back face material color of an existing advanced display mode, as see in Options > View > Display Modes?
Yes.
You might start here:
Rhino - Rhino.Python Guides
– Dale
Sorry to necrodive here, but, R7 and R8 showing backfaces as a colour only works on open geometry i make, not any closed geometry?
Have a missed an obvious way to detect flipped normals?
(visually i mean, like with a backface setting, not the dir command) so our team can outdetect these
testfile.3dm (6.1 MB)
The Dir command is useful.
– Dale
Hi Dale thanks but we import several hundred to thousands of customer supplied parts and not always easy to see which ones might be buggy till we get to slicing, i dont want o have to run a command on every part, I’d like a view port to show it like it does with backfaces colours to trigger a warnign to staff.
