Axonometric view in Rhino
Hi! How can I set an axonometric view in rhino? Is there such thing?
in the top viewport, rotate your model 45 degrees. then in the right viewport, select your model, type in the ‘shear’ command, enter ‘0’ for your origin point, then anywhere in the ‘z’ direction for your second. enter ‘45’ for you shear angle.
i don’t believe this is a pure axon, but it gets the point across.
Maybe _Isometric is acceptable, NE, NW, SE or SW
