Hi, this is a more architecture drawing related question, how would you set up your model to be in this kind of planometric or “zero degree axon” view, for axonometric drawings we rotate the model 45 degrees and then shear it, is there a similar process for this in rhino? I have attached examples of what I am looking for:
Hi @Kaamil_Hasan_Dahodwa
It’s exactly the same as the axo drawings - you just skip the “rotate 45°” part, and simply shear the model at 45° in the right (or left) viewport and the top view is good to go.
HTH, Jakob
Thank you, much appreciated!
