I ran a script called “AutoCPlane Enter” when rhino start but I can´t find it, how can I get this function on R6?
Hello - what does it do?
when I rotate the view cplane adjusts to draw in that view, in the top right create the name of the cplane.
Hello - use the OneView
command.
thank you !!
@pascal sorry to revive this post but one view does not working for me in R7
Hi -
Could you explain what that means?
this but in r7 nothing happen
Hello- does the command run at all? Is there anything at the command line? If not, verify the ‘commands’ plug-in is enabled -
Oh - ok so it runs - and as you tumble the view, nothing changes? Set MaximizePerspective=Yes to make sure you are dealing with only one viewport.
I was changing checking the options but cplanes just not changes to the view
in R6 no problem
Hello- please run the Rhino command SystemInfo
and Copy/Paste the results here…
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 7.9Gb)
Computer platform: LAPTOP - Plugged in
Primary display: Intel(R) HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y).
> Integrated graphics device with 2 adapter port(s)
Primary OpenGL: NVIDIA GeForce GT 555M (NVidia) Memory: 3GB, Driver date: 3-23-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 391.35
> Integrated acclerated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-23-2018
Driver Version: 23.21.13.9135
Z-Buffer depth: 24 bits
Total Video Memory: 3 GB
C:\Program Files\RhinoNestRhino6\System\RhinoNest.rhp “RhinoNest” 4.6.18354.2
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21012.11001
Hi -
Please post the complete system information.
Rhino 7 SR2 2021-1-12 (Rhino 7, 7.2.21012.11001, Git hash:master @ 2f08cf516ffc716c4c4a369abf7625798ef79bca)
License type: Corporate, build 2021-01-12
License details: Stand-Alone
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\import_OBJ.rhp “Import_OBJ” 7.2.21012.11001
Hello- it appers you have a cracked Rhino. That is unlikely to work.
Really is a shame but soon I´ll grab one. so auto cplane works only if you don´t use the view car icons right left etc.
You must be in isometric icon so autocplane run well, in R6 didnt matter if you used the car icons, Maybe is a little bug, maybe not.
