Automatic CPlane
Is there a command that I can auto-flip the cplane in the direction I locked the camera when I lock the perspective with ctrl shift in the perspective camera?
Hi Agah - try OneView - does that do what you want?
Thanks Pascal, I learned a lot from you :slightly_smiling_face:
Hello @pascal and @agaheroglu,
I tried _Oneview, but when I lock the view with Ctrl+shft in a perspectiv view, it doesn’twork…
does it works on your rhino…
V7 or V8 same issue
If you go to the degree you set and shift ctrl, it will work.
When I lock the Vue, that seems deactivate the oneview function…
Hi Franck -
How does Ctrl+Shift lock a perspective view?
Please try to describe in detail what you are doing.
Ok… so I activate oneview. the view name appears in a text box at the top right of the perspective view, it changes when rotating the view to the right or left depending on whether I’m approaching an orthogonal view. still during rotation, I block the view with CTRL and shift, and at that moment, the text box disappears, and if I am not perpendicular to the xy plane, then I can’t draw anything… I will try to do a video if needed on Monday…
Thanks :pray:
It appears drag and then CTRL+SHIFT is a shortcut to have a plan view.
I think it would be useful if the name of the current CPlane would remain visible on the screen
and above all that we can draw like this we were on the right or left window…:sweat_smile::blush:
I’ve been using rhino for over 14 years, and I discovered this shortcut only a few weeks ago, I said to myself: damn! This shortcut is great, no need to navigate from window to window…
besides, are there shortcuts to switch from one display mode to another? Just only one press button…
Check this topic: Hotkey to switch between all the different display mode ? Urgent <3 - #2 by Mahdiyar
