Cycle through cplanes?
Hey!
Any way of doing this?
And more in general - can I cycle through a pre-defined set of commands somehow?
I was thinking if the above doesn’t work maybe I could cycle through:
'_CPlane
_Top
'_CPlane
_Left
etc.
Thanks!
Pelle
_CPlane _World _Top
_CPlane _World _Left
Shift+Home restores the previously used CPlane in the current viewport.
Shift+End restores the CPlane that was active before the Undo option was used.
Ctrl+Tab activates the next viewport.
Ctrl+Shift+Tab activates the previous viewport.
You can also use NamedCPlane.
Hi, thanks for your reply.
I’m modelling 99% in perspective view, so viewports is not for me though in this case.
Resetting cplanes, sure, but it would be nice to cycle to the next one with the click of a (mouse) button and know that that one is top, next left etc.
Would it be possible to do with a script perhaps?
NamedCplanes I have in my sidebar but I would prefer to not have to go there everytime, because I use cplanes a lot.
Thanks
Pelle
Add to @Mahdiyar 's suggestions Oneview
Cool!
But I’m still on v5 (vsr / t-splines)
That looks like exactly what I need though.
I’ll just bind my cplanes to different keys for now I guess and contemplate if it’s time to make the jump.
Still I think that being able to cycle through commands with a single button would be cool.
hello - you can try this plug-in, which (I think) works in V5 - it was the prototype for the OneView command - I think it more or less works…
AutoCPlane.rhp (18.5 KB)
You’ll need to unblock the rhp in Windows and then drag and drop it from the save location onto Rhino.
Pascal, you’re too nice!
Thanks a lot, seems to work great!
I do get an error using certain tools though:
Error: ‘NoneType’ object has no attribute ‘Document’
I don’t expect you to fix this for me, and everything seem to run fine anyway.
I’m just wondering if this could be anything, or if it’s very specific and I can look for a solution for it.
edit: hm, I seem to get it when using materials, materialeditor, decals etc.
Thanks
Pelle
