Array spacing
Is there a one step tool that works like linear array but uses that last object for spacing instead of the first. This seems more practical.
Level on user.
Hello - Distribute, after the array is made , may help for now.
Maybe also the command _TweenCurves to arrange the centerlines of these pillars?
You can use “Array along curve” instead, because it’s quite powerful when combined with History turned on. After the array, you can basically turn on the control points of the input curve and edit it by manually dragging its control points to the desired position in the 3d space, in any direction. The resulting objects will follow the changes immediately.
