Array along a surface ? Along 2 curves
Help with arraying a curve (BLACK) either along a surface or along 2 curves (RED) (the result should be the same). I would like to have 120 copies of the curve arrayed along the surface. Thanks
You’d better provide rhino model or GH file so that everyone can continue better
You might want to look at this post:
Of course, with 120 sections, you’re probably better off concocting a GH definition.
Rhino model
Array along curves or surface.3dm (369.6 KB)
What is the best way to pipe a steel i-section profile along a series of curves? Extrude and Sweep both give deformed objects after running. Thank you
it seems you have already asked the same thing before
Array along curves or surface.gh (104.9 KB)
Since you already have the surface in there, perhaps this GH definition might work for you…
Srf-VIsocurves.gh (7.2 KB)
another possible way
project.gh (102.4 KB)
A non-Grasshopper method:
Array to create 121 parallel lines. (Length and spacing are not important.)
Plane to create a rectangular surface containing the parallel lines.
Delete one end line to prevent duplicate lines at the seam of the closed surface…
FlowAlongSrf the parallel lines with the rectangular surface as the base.
or polar array and project the curves from the top view
Thank you all for the suggestions. i have it sorted out now
This was for piping a cross-section profile along the curves. I generated some curves manually initially. Thanks
