Application support environment hdri missing in m1 MacBook Rhino 7
For some reason my folder application support environment hdri is not available or hidden somewhere since downloading rhino 7 on m1 MacBook
Can’t find it anywhere. Hdri is working ok in 8 but not 7
Hi @studiocathal ,
Apple made a change in the last Ventura update which caused the Render Content folder to not be directly opened from the Environments or Materials panels. It’s still there in your User Library but hard to find. One alternative is to use the Libraries panel in Rhino which still finds it. Regardless, we have a fix in the service release candidate for Rhino 7.29 which you can try here https://files.mcneel.com/dujour/dmg/rhino_7.29.23107.03002.dmg now, please let me know if this helps on your end too.
Hi Brian,
Yes that fixed it fine. Many Thanks
Cathal
