Hi there,
I have two issues, as the following.
1- I can’t see the environments in the preview !! as I’m using MacBook .
The second issue in the rendering does not show good quality; as you see below screenshot it’s not 100% Clear
Hi there,
Hello- please run the SystemInfo command in Rhino and post the results here.
Rhino 7 SR19 2022-6-29 (Rhino 7, 7.19.22180.09002, Git hash:master @ 87eeb0270c74a3e5ecc603402afbf263ed32b37d)
License type: Commercial, build 2022-06-29
License details: Cloud Zoo
Apple macOS Version 12.5 (Build 21G72) (Physical RAM: 64Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,4
Language: en-SA (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 48 GB
Graphics: Apple M1 Max
Displays: Unknown (102dpi 1x), Unknown (255dpi 2x)
Graphics processors
Apple M1 Max
HP E223 (1920 x 1080 @ 60.00Hz)
Color LCD (1512 x 982 @ 120.00Hz)
USB devices
Realtek: USB 10/100/1000 LAN
VIA Technologies Inc. : USB 2.0 BILLBOARD
USB Storage: USB Storage
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.19.22180.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.19.22180.9002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.19.22180.1002
For the rendering, you may want more samples - I beileve the default is 50. And, you may want the denoiser - run PackageManager command, and search for and install the ‘Intel denoiser’ and then enable it in Properties for the raytraced viewport. Does that help?
yes, thanks a lot
