I was wondering if there was a way to adjust the settings in Rhino to create a similar line style that sketchup uses? Specifically the outside edges to be thick and the inside edges to be lighter. Rhino seems keep all edges the same width.
Hi Collin -
The technical display modes (e.g. Technical and Monochrome) have settings for silhouette edges.
you just need to customize a display mode
(ok, i’ve noticed you are looking for a silhouette effect, you should try to work on a artistic display mode copy)
You have a lot of display modes ![]()
yes!
some are for product viz, others for product design, others for working with scanned objects, some for teaching…
Share them here Shared viewport styles !!!
