I would like to mimic the SketchUp look, you know the heavy outline, solid fill, and grayish shadow. Was wondering if anyone has setup this up before and saved it out. I was tweaking the settings and did not quite get the look. The gray shadows dont look that good. Thanks.
I am also looking for sketchup display settings for Rhino. If you have pre-settings could you share with us also?
Thank you!
Try this Rendered like sketchup.ini (12.8 KB)
Hope it helps - Nate’s Studio Desk
These are some display modes i made. Hope you find them helpful.
Display Modes:
04_Conceptual.ini (13.0 KB)
07_Revit Style .ini (13.9 KB)
09_Arctic With Outline.ini (12.9 KB)
12_White and Lines.ini (13.6 KB)
14_Plain Colors and Lines Shaded.ini (13.9 KB)
15_White and Lines Shaded Colored no outline.ini (13.9 KB)
This is how i made them if you are interested:
I hope McNeel will set this type of display as the default for Architect.
in RhinoWIP there is the option to use the command ‘Flair’. I believe it s basically some NPR display modes, very promising imo ![]()
Hi @intuitionusa In case you haven’t seen this, we’ve added a new Display Mode called Concept in the Rhino BETA that might be related to what you’re looking for.
