Render version: 4.6
Shading Language: 4.60
Driver Date: 4-15-2019
Driver Version: 26.20.11002.1001
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
I saw the same on my testmachine after updating win 10, the drivers for the wx7100 and rhino… all up to date at the same time so I don’t know what caused it, but it smells like driver errors.
I have an AMD processor, but it’s things like this topic that makes me wary of AMD video cards, though they often have better compute performance, because AMD doesn’t hobble them as much as nVidia.
If I stop seeing stuff like this, certainly I will reconsider AMD for my next video card purchase.
Hi - the glitch is very similar to something that we have seen on a very specific configuration of Mac hardware. We have just solved that particular issue and so I was wondering if you would want to test if this also fixes the problem you are having.
Thank you @wim, I have tested and now it is working properly. However their is still a strange behaviour that still remains. The wire frame of the mesh is not clipped properly.
Hi - good to hear that something is working better now.
Are you saying that it is now only for mesh objects that the clipping plane is causing this behavior?
Could you post a simple file that shows this on your system?
The issue was fixed for both Rhino 6 and 7 but you’ll have to wait for a 6.23 release candidate to see that in Rhino 6.
sorry for the late reply but ts very busy at work these days. test.3dm (2.4 MB)
I believe the problem appears in all surfaces, only that it is more obvious on mesh, because there is a lot of it and also it has strange pointy edges.
So here is an example file. I hope you will find it useful.
If you manage to correct this issue as well, you could try to include also this one in 6.23.
Hi @andreasor81 - no, I didn’t have any problems opening that file, which, in a way is bad because I couldn’t reproduce the issue. The developer hasn’t been in but I’ll put this in a YouTrack report so that it can be followed up.
A few more questions:
Which display modes do you see this effect in? Are those factory-default modes? (you can tell if they have been modified by looking in Rhino Options > View > Display Modes. If the list in the left-hand column has anything in blue, that means that that mode has been modified).
Could you post a screenshot of a scene with a simple NURBS box that is clipped?
