Add shared parameters to families
Is it possible to add shared parameters to families?
Family.New doesn’t have an input to do so, and I can’t find a component to edit existing families to add parameters. I hope to create shared parameters and add them to families in Grasshopper, but I’m not sure if it’s even possible.
Hi Dongyeop is this still an issue for you? Do you still want to make shared parameters?
I’m not sure if it existed when I posted the question, but I found this method at some point…
Thanks for looking into my question!
Does it work? I can’t seem to make it work
Define Shared Parameter seems to be removed from later versions of RiR?
Here is how you add a shared parameter to a project.
