Hi all, I wonder if there is a way I can add dimension to the grid above in one go.
I found that there is a Add Dimension component in RIR but I am not quite sure what I should input for the References and the Line…
Hi @Jack_Zeng
here is the brief intro to this component
You need to add detail lines here as a reference. Gridlines are considered as a valid reference by this component.
check the following link for the more advanced workflow
Great, thanks Muhammad, may I ask for the link of the PARAMETRIC PLANET? I have tried to search it but with no luck.
hi @Jack_Zeng
Here is the Link
Many thanks, Muhammad
