How to create aligned dimension instead of linear?
cannot find it
The Revit UI is using the same method behind the scenes.
more details here… https://thebuildingcoder.typepad.com/blog/2017/01/vertical-dimensioning-and-revit-api-qas-research.html#2
The Add Linear Dimension does both, depending on your Line input.
thank you
let me try it
Beautiful, thanks Japhy!
