Add color to object in Artistic mode?
I like the look of artistic mode, but client often wants to see some colors added to the objects. I don’t want to necessarily render with materials, but rather use layer colors and have them come through semi transparent in the artistic mode view… I just want them to be faint, not saturated. Is this possible? How? Thank you.
Run the Options command.
Go into View > Display modes, and make a copy of the Artistic display mode.
In the copy, check the option for Shading.
Set the viewport to use the copy of Artistic.
This will make the objects display their layer color.
Tweak the color of the layer in the layer Panel to suit.
Thank you. That worked!
