If I place this family with Revit UI, it works fine, two clicks and bam it´s there. But if I place it using RiR, the adaptive points are visible in the model, the node says it created the adaptive element, but that´s all. The family type itself is somehow not there. I can select the adaptive points, but the type itself is not selectable (unlike the other created using mouse clicks) and I see no model line of the family.
thank you very much for a hint. Trying this in a fresh RVT file it definitely works ok.
Anyway the model I´m working on still doesn´t accept it. I´ve aready purged everything out with no luck.
Could you please look at attached files to see what´s wrong with the RVT model in this case? We would like to avoid these mistakes in the future. The slopeLine family is already loaded in.
