When creating a new layer it shows up highlighted with some ‘layer (#)’ name assigned. Because it’s highlighted I automatically begin typing in a name I want to use and then… I find the command menu showing up on my main window. Then of course I must back up and double click to get into the titling function on the new layer. Why cant a new layer created be ready for a title the first time round instead of requiring the additonal clicking?
I’m afraid I don’t follow this request. When I click the + button in the Layers panel, I can immediately start typing a new name.
Here’s a vid. When I click to make a new layer the name is highlighted but typing takes me to the command dialog box
Thanks for the video. That’s really odd. That’s certainly not what I’m seeing. I have tested this with both Command options in sidebar and Command options dialogs, with the same result. Can you please run ExportPreferences
and send along your .plist file?
Hi Dan!
Better late than never.JAMES KAYTEN.plist (343.2 KB)
Thanks @JKayten-
Do you still see this behavior in the latest RhinoWIP or is this a Rhino 5 for Mac issue only?
I’m running version 5.5.3(Mac)
I didn’t know there was a 6 out.
It is not available for purchase yet, but rather in the Work-In-Progress WIP stage. If you have a license of Rhino 5 for Mac, you can access the RhinoWIP for V6.
Hi - I see that here on my system as well.
Reported as RH-51963.
Thanks!
Has any progress been made with this. It’s a minor thing but I constantly forget the highlight on the new folder is not a proper highlight and I start typing only to call up the command line box!
It looks like this is difficult to reproduce systems in Seattle. I see it happening here, though. In the Rhino 6 WIP, please run SystemInfo
and post the result here.
The bug item is open and is being further investigated by the developer and perhaps your system information can provide more clues.
Thanks!
Here ya go!SysInfo.txt (10.6 KB)
Hi - I get a Not found
error when I click on that link. Could you try once more?
I see, I didn’t know I couldn’t up a text file.
Rhino 6 SR15 2019-4-23 (Public Build, 6.15.19113.12066, Git hash:master @ 274a338b3750a50e31b20e180064bac7a51647da)
License type: Beta, build 2019-04-23
License details: Cloud Zoo. In use by: James Kayten ()
Expires on: 2019-06-07
Apple Intel 64-bit macOS Version 10.14.3 (Build 18D109) (Physical RAM: 40Gb)
Mac Model Identifier: iMac18,3
Machine name: Avery’s Mac Pro
Language: en-US (MacOS default)
AMD Radeon Pro 570 OpenGL Engine (OpenGL ver:4.1 ATI-2.4.10)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Graphics: Radeon Pro 570
Displays: iMac (173dpi 2x), DELL U2717D (109dpi 1x)
Graphics processors
Radeon Pro 570 (4096 MB)
iMac (2048 x 1152)
DELL U2717D (2560 x 1440 @ 59 Hz)
USB devices
VIA Labs, Inc. : USB3.0 Hub
Cable Matters Inc.: USB-C to DisplayPort Cable in 4K 60Hz
Logitech: USB Receiver
Broadcom Corp.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
VIA Labs, Inc. : USB2.0 Hub
Initio: DVD±RW SDVD8820
Brother: HL-2270DW series
Canon: CanoScan
PixArt: USB Optical Mouse
Bluetooth devices
None
Third party kernel extensions
com.logitech.manager.kernel.driver (6.94.1) A2DAB204-3717-3C10-9E8C-D6345AEF4507
at.obdev.nke.LittleSnitch (5264) A3F04A53-C3F3-33C5-94A1-DE80FB9F7634
com.Logitech.Control Center.HID Driver (3.9.5) no UUID
com.Logitech.Unifying.HID Driver (1.3.5) no UUID
com.bitgapp.eqMacDriver (1.5.2) 7FF03650-6287-37A9-B143-66F52FC42035
com.hzsystems.terminus.driver (4) A34AA04A-490F-DEE3-BF42-CDAE5B86833D
com.AmbrosiaSW.AudioSupport (4.1.4) no UUID
com.bongiovi.DPSReflector (1.0.6) 249CC5D7-6845-38A7-96D9-D5A5236126EC
com.techsmith.TACC (1.0.2) CDFE6E94-C4F0-3281-9366-7B8DA225A688
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
Rhino plugins
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp “MPlane” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp “STL Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp “Points Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp “Points Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp “X Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp “STL Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp “X Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp “Squish” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 6.15.19113.12066
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp “Import_M” 6.15.19113.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 6.15.19113.12066
wim https://discourse.mcneel.com/u/wim Wim Dekeyser https://discourse.mcneel.com/u/wim McNeel
April 30
Hi - I get a Not found error when I click on that link. Could you try once more?Visit Topic https://discourse.mcneel.com/t/a-small-request-labling-layers-function/73040/16 or reply to this email to respond.
In Reply To
JKayten https://discourse.mcneel.com/u/jkayten https://discourse.mcneel.com/u/jkayten
April 30
Here ya go!SysInfo.txt https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/6/f/6f70cc77b0249bf6f48b4dcda218771f79e9b8c6.txt (10.6 KB)
Visit Topic https://discourse.mcneel.com/t/a-small-request-labling-layers-function/73040/16 or reply to this email to respond.To unsubscribe from these emails, click here https://discourse.mcneel.com/email/unsubscribe/dfb48717a5c32ef21494b9d39daa3c846ed7d380504e4846e865e474209216eb.
SysInfo.txt (10.7 KB)
