Hello again,
A separate topic for new suggestions to simplify readability and replies
“Insert Edge” nomenclature : “parallel” and “perpendicular” instead of “loop” and “ring” that are confusing . “Parallel” inserts edges parallel to existing ones and “perpendicular” inserts edges that will be approximately perpendicular to existing ones.
“Enter when done" should be implemented in the “Insert Edge “ command, to allow multiple new edges to be created with left clicks. Only when “Enter when done” is applied would the command be terminated.
Convert to SubD and Convert to Nurbs buttons too similar (see suggestion for improvement)
The “merge faces” button looks like a “delete face” button as the red cross on it is misleading (see suggestion for improvement)
5) “Cage edit” command must signal that does not work with SubD objects
“Record history” must signal when the history is broken after moving a SubD object
The way the “reflect” command updates is not very practical
“Insert points “ command that will be translated in edges causes errors (see example and attached file)
Add points bug.3dm (64.3 KB)
Again congratulations on the SubD project !
