I’m having a problem with edges/lines not showing when I switch to the PEN display. Everything looks great except for no edges for the radius on my part. Is there a setting in RHINO to have the edge lines of radius show up? Or is that not possible? I added a red line to show what I’m referring to.
THANK YOU FOR YOUR HELP!
Under Panels menu, check Display and try out the options there.
No luck Thanks for the suggestion. I’m stumped, when I rebuild the part in Rhino I get 2 lines for the tangent points that define the radius.
I’m sure I misunderstood. You want Rhino to paint the radius as though it is an edge? If so, maybe just split the surface where you want to see a line?
Yes that’s it. Great idea on splitting it. Thank you for taking the time to help me. I just downloaded the 90 day trial yesterday.
Much appreciated Ken
