I have a bit of a weird workflow question but I am hopefu there is a rhino inside node or a python code way I can do this.
Basically what I want to do is take a view-
And extract the line work (keeping categories or sub categories) and then pass that into rhino with the corresponding layers (categories) and then locate it within rhino where I want it.
Essentially automating the manual process of exporting a plan for example of a dwg and then importing it into the rhino space.
I want to do something similar but I want to be able to take day a 2d plan with linework from revit
And bring it in as 2d linework in the rhino environment.
I believe I could export the dwg from revit and bring it in as a work session into rhino and then manipulate it.
But is there a way I don’t need to export it from revit- but rather use rhino inside to simply produce the linework directly in grasshopper and the bake it into the correct layers?
