At random times the two finger pan on my macbook pro goes form the desired pan/rotate to zoom. This happens toggling back between apps and when returning to my mac after its a sleep. Im not sure what causes it. Is there a setting or a hot key that toggles this on and off.
Someone suggested checking settings > trackpad and the “Use two fingers to pan and rotate views” is checked. I have tried toggling this with no change
Another suggestion was check zoom factor is set to 1 but this is very very outdated.
Any suggestions?
