anyone else experiencing this? I rolled out the 1.17.8732 update last night and this morning users reporting issues where Rhino is asking them for license when opening a revit file, I noticed at the time all our rhino licenses were pulled. I tested and yes once opening revit file a rhino license is pulled. it used to be only when starting RiR would it pull a license, is this an intentional revision to how RiR functions?
this is with revit 2023 and 2024 from my limited testing.
I will be rolling back to v1.16 for time being.
also, i had downloaded from the RiR website and received 1.17.8620.27747, then upon installation, opened revit and went to RiR tab, it noted there was a new version available, that was where I could download the 1.17.8732.19724 which caused the license pull issue. confirmed roll back to 1.16.8620.27572 has stopped the license pull upon opening a revit file.
can confirm the fix added to daily build does not pull a license upon opening a revit file. clicking start in RiR tab does pull license as expected, once revit.exe finally stops as a process the license is returned. thank you also for the quick response and resolution!
